Date/Time: Thu, 26 Nov 2026 04:57:48 +0000
Numbers bars not supported
View Count: 426
| [2026-06-04 12:13:35] |
| User660632 - Posts: 1 |
I'm on package 3 base standard but Numbers Bars study shows as not supported on package 0. I've logged out and back in and restarted Sierra Chart but the issue persists. My usage time is active until 5 July 2026.
Date Time Of Last Edit: 2026-06-04 14:02:28
| [2026-06-04 14:52:36] |
The package you are on does not support the use of the Numbers Bars study, along with a few others. You need to be on one of the "Advanced" packages to have access to the Numbers Bars study. Refer to the information for the packages at the following link: Description of Service Packages and Pricing: Packages Refer to the following for how to change your package: Sierra Chart Purchase and License Information: Changing Package For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
