Date/Time: Thu, 26 Nov 2026 04:57:45 +0000
New Software Issues
View Count: 383
| [2026-06-03 04:56:18] |
| User223734 - Posts: 120 |
Dear Sir , I am using 2813 version, I noted the current version 2915 the chart edges (boundary) is different when compare to 2813. I like the 2813 version and the chart edges is more clear. Can I keep using it without upgrade to the latest version? May I know the latest software version which have the same chart edges as 2813? |
| [2026-06-03 13:22:36] |
Please get us an image of what you are referencing in terms of the "chart edges", as we are not certain of what this might be referring to.
| [2026-06-03 13:56:12] |
Please advise the software verion between 2813 and 2915. I will try it by myself.
| [2026-06-03 14:19:50] |
Sorry, we did not realize you were referencing version 2813 - we were thinking 2913. There are significant changes to the windows that are contained within the main Sierra Chart application in recent versions. But, since these are now managed by Sierra Chart itself, and not the Operating System, you can change the settings related to these. Please take a look at the settings starting at the following link, and the 5 items below it, related to the "edges" of charts in the recent versions: Graphics Settings: Window Title Bar We think you will learn to like these new items due to these controls. The latest release that does not include those changes is 2813, the version you are currently on. We can not say how long you could stay on 2813. We never know when a particular change for data or trading, could require a person to update. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-04 10:01:54] |
Dear John, Thank you and understand. Can you tell me what are the software versions after 2813 and before 2915? |
| [2026-06-04 14:30:12] |
We are not understanding what you are asking for in this question. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-04 14:43:50] |
I mean all of your software revision which is after 2813.
| [2026-06-04 16:12:21] |
In general, there is a software revision at every integer number. So there is a release at 2814, 2815, 2816, etc. We do not update the What is New section for every release, but you will find what we do post here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
