Date/Time: Thu, 26 Nov 2026 04:57:48 +0000
Why was the
View Count: 226
[2026-06-02 19:17:36]
User327465 - Posts: 23
In previous versions of Sierra Chart, there was a "Line and Point" subgraph draw style that drew a continuous line with a dot at every bar. This appears to have been removed in recent versions (I'm on 2915). Could you explain why it was removed, and is there a direct equivalent replacement? The workaround of stacking two subgraphs (Line + Point) works but is cumbersome compared to having a single draw style.
Thanks!
[2026-06-02 22:14:02]
If there was a "Line and Point" draw style, it has not been in the system for many years. There also have not been any changes to these items anytime recently.
There are draw styles for "Point and Figure" and "Point and Figure XO", which are still available, if you were thinking of those. They can only be set through the "Chart Settings" window, which has always been the case for these.
