Date/Time: Thu, 26 Nov 2026 04:57:46 +0000
Unexpected blank space to the right of the Right Side Values Scale
View Count: 319
[2026-06-02 08:45:04]
User707785 - Posts: 10
I am suddenly seeing a blank/empty area to the right of the Right Side Values Scale in one of my chart windows, and I cannot figure out how to remove it.
The issue is visible in the attached screenshot. There is an empty vertical space on the far right side of the chart, outside/right of the price scale.
To clarify, I am not referring to the Fill Space on the right side of the bars. I am specifically referring to the empty space that appears to the right of the Right Side Values Scale.
The issue occurred after I was experimenting with the following settings:
Show Market Data Columns
Draw DOM Graph on Chart
Trading Chart DOM On
These are all currently deactivated again, but the empty space on the far right side remains.
I have already tried the following:
Resetting the chart scales multiple times
Removing all studies from the chart
Restarting Sierra Chart
Checking the chart region and scale settings
None of these steps removed the blank space.
https://www.sierrachart.com/image.php?Image=1780389436759.png
[2026-06-02 08:48:01]
Sierra_Chart Engineering - Posts: 25491
We want you to update Sierra Chart to the latest release, and see if the problem continues. Instructions:
