Date/Time: Thu, 26 Nov 2026 04:57:47 +0000
The Remote Build returns "The compiler response is empty" for every study I try to compile
View Count: 339
| [2026-06-02 02:17:59] |
| User217133 - Posts: 1 |
It is not specific to one source file. It started around 19:30 US Eastern on 2026-06-01 and is still failing at 22:08+ — over 2.5 hours, persisting across a full Sierra Chart restart and a long idle period with no build attempts, so this does not appear to be transient throttling. Earlier the same day (around 19:05) remote builds were succeeding normally. What I've already ruled out: It is not source-specific — I built a different study as an isolation test and it fails identically. It persists across a full Sierra Chart restart (quit and relaunch). It persists across many retries over 2.5+ hours, including after a long break with no attempts. The connection itself looks fine: it connects via TLS 1.2 to build.sierrachart.com and the socket is gracefully closed by your server — but the compiler result comes back empty (~9–10 seconds, then "empty"), after which Sierra just unloads and reloads the previously built DLL. Could you please check: Whether the remote build server is currently experiencing an issue, and Whether my account is being rate-limited / throttled or otherwise blocked on the build service. Representative Message Log excerpt: HTTPS connection ID:1 to build.sierrachart.com:443 ... | Connecting to IP: 69.39.70.252. The compiler response is empty. Setting study DLL module function objects to indicate DLL is not loaded: Y:\SierraChart\Data\FWD4.dll Unloaded DLL: Y:\SierraChart\Data\FWD4.dll. Handle: ... Loading DLL: Y:\SierraChart\Data\FWD4.dll (FWD4_64.dll). Handle: ... HTTPS connection ID:1 to build.sierrachart.com:443 ... | Socket gracefully closed by remote side. Thank you. |
| [2026-06-02 07:55:22] |
| Sierra_Chart Engineering - Posts: 25491 |
In the "Build Output" section of Build Advanced Custom Studies window, select all the text there, copy it and then pasted here. So we can have a better understanding of what is happening.
