Date/Time: Thu, 26 Nov 2026 04:57:41 +0000
MBO data: Rithmic DTC vs Denali — current status?
View Count: 850
| [2026-06-01 08:28:52] |
| User_saxony_04179 - Posts: 1 |
I am on Package 12, using Rithmic for order routing. I am also holding a live funded account at AMP Futures for Non-Professional CME data verification. Based on my research (documentation + Support Board Thread #46257 from 2019), my current understanding of the setup is as follows: - MBO data in the Sierra Chart Trade DOM is exclusively available through the Denali Exchange Data Feed - The Rithmic DTC connection does not consume or expose MBO data in Sierra Chart, regardless of whether an MBO add-on is subscribed to at the broker level - Rithmic is used solely for order routing in this setup - Denali is configured as the data source (realtime + historical) in parallel with Rithmic trading connectivity - In the Rithmic service settings, Market Data and Historical Data credential fields must be left blank once Denali is active, to avoid permission denied errors Has anything changed regarding MBO support via the Rithmic DTC connection in recent Sierra Chart versions? Or is Denali still the only supported path for MBO data in the DOM? |
| [2026-06-01 16:29:01] |
There have been no changes to what you state. If you want to view MBO data, then you have to get that data from our Denali Exchange Data Feed. -- Just so you are aware, the exchange that you had active in May did not renew on June 1, 2026, as your account was not active at that time. If you want to get your data from our Denali Exchange Data Feed, then you need to activate the exchange(s) for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
