Date/Time: Tue, 20 Oct 2026 18:28:46 +0000
DOW Level
View Count: 354
| [2026-05-31 00:20:15] |
| Crtfyd - Posts: 310 |
Why is my DOW chart(LOADED DOW[M] ) in the 30s, when the actual DOW is above 50,000? I dont see any notation that this is an ETF/ I searched symbol for DOW, and got this intraday chart |
| [2026-05-31 03:45:09] |
| Sierra_Chart Engineering - Posts: 25226 |
That is a stock symbol for Dow Inc.
| [2026-06-01 15:59:45] |
| John - SC Support - Posts: 48273 |
We have End-of-Day data for the Dow Jones Index. The symbol for this is $DOWI. You will find this listed in the Find Symbol window under the section for "Cash Indexes (End of Day)".
| [2026-06-01 16:20:03] |
Thank you. Is this part of my Pkg 10?
| [2026-06-01 19:00:57] |
It is available with any package.
| [2026-06-01 19:42:56] |
Thank you. I loaded it fine. But theres no data for today. As far as I know, todays not a holiday. Are these deleyed? |
| [2026-06-01 23:35:49] |
I finally got today to load after the close, which makes me think this is delayed...but 1 day delayed? I wanted 1 sec bars, and its set for that (0-0-1), but it only goes to 1 minute bars. Can this not do 1 sec bars? Also the Cumulative Delta Bars - Volume doesn't work. No data (the Delta vol Up/dwn tick does however) (?) thank you Date Time Of Last Edit: 2026-06-02 00:13:22
| [2026-06-02 14:27:39] |
As was stated previously, the $DOWI is "End of Day" data. Meaning that it only updates at the end of each day. There is no real-time data for it. The data is in 1 minute increments, that is all it is, there is no ability to get anything smaller than that. The Cumulative Delta Bars - Volume does not work on the $DOWI? That is because there is Bid/Ask data, so there is no delta. If you are having a problem with this study on another chart, then what is the symbol of that chart? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
