Date/Time: Thu, 26 Nov 2026 04:57:40 +0000
Adding actual volume threshold to the Large Volume Trade Indicator study
View Count: 464
| [2026-05-30 14:07:58] |
| HeidiT - Posts: 16 |
Hi! I understand on the large volume trade indicator there is a percent threshold one can use to to help normalize the bubble size when assessing the size against all loaded chart bars. When I set the upper limit (percentage above median for maximum volume in chart) to 2%, it is still difficult to differentiate the differences in the sizes of the smaller bubbles. Some days it works OK, but days when we have larger players, I have to switch to visible bars only, and that setting is inconsistent. I was thinking it would be super great if you could add an option to cap the volume that sets off the max bubble size with an actual volume number, so I can still see the differences between smaller volume ranges when a ~1000 lot goes off. For example, in the NQ, I would probably set this to 100, then sure, the orders over 100 will all be the same size (max), but I will still be able to see the differences in the smaller ranges and the sizing will be more consistent than when using the visible bars only function. I hope that makes sense. Thanks so much! Heidi |
| [2026-06-01 15:30:40] |
We have set this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
