Date/Time: Thu, 26 Nov 2026 04:57:45 +0000
CVD Candles reset at 0 for hourly candles
View Count: 350
[2026-05-30 00:06:45]
User794005 - Posts: 51
I have four hour or one hour chart that I use quite often, and I would like to see every candle of CVD corresponding to the candles of price. I understand that there is a setting that resets every day, but is it possible to reset it every candle? Check circled CVD in the attached image
imageScreenshot 2026-05-29 at 7.57.39 PM.png / V - Attached On 2026-05-30 00:06:14 UTC - Size: 146.65 KB - 141 views
[2026-06-01 15:24:00]
If you want the Cumulative Delta - Volume to reset with every bar, then set the following Inputs for that study:
- Perform Rolling Calculation: Yes
- Rolling Calculation Length: 1
