Date/Time: Thu, 26 Nov 2026 04:57:45 +0000
Service Package 11 Two-Week Trial?
View Count: 1026
| [2026-05-29 15:22:07] |
| User528002 - Posts: 27 |
Good morning, I have Service Package 10 and wanted to try out Numbers Bars (the Footprint Chart). I understand that I need to upgrade to Service Package 11 in order to do that. Is there anyway you could give me a two-week trial of Service Package 11 so I can test it out and determine whether it makes sense for me to switch to? Many thanks, Edward |
| [2026-05-29 15:49:33] |
There is an option to evaluate the highest level package for 30 days. So this would give you the capabilities of Package 12, which is Package 11 plus the Market by Order information. Refer to the information for Package 12 at the following link: Description of Service Packages and Pricing: Sierra Chart with Advanced Features and Market by Order (Service Package 12) To activate the evaluation, select the link for "Evaluate Highest Available Service Package" on your Account Control Panel. It is near the middle in the line that has "Current Service Package" on the left. You can access your Account Control Panel by selecting "Help >> Account Control Panel" from within your Sierra Chart software. Note that this is an "Evaluation" and not a "Free Trial". So you still need to have an active package in order to be able to use the system and have the highest package capabilities. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
