Date/Time: Thu, 26 Nov 2026 04:57:48 +0000
installed latest verswion of sierra chart and behaviour is funny
View Count: 441
| [2026-05-29 13:58:09] |
| User161159 - Posts: 49 |
funny behaviour 1. Unable to scale on any chart 2. Moving averages is not correct. I have attached example. |
| [2026-05-29 14:03:08] |
also the studies are not showing up
| [2026-05-29 14:13:13] |
Like to withdraw my request. I restarted sierra chart and the issues vanished. Sam |
| [2026-05-29 16:53:26] |
| Sébastien - Posts: 156 |
Study are not showing up : I had the same bug once this week using v2913. But as said, a simple restart fixed the problem. Also, on a DOM, when the price scale is hidden, the price scale width cursor never get deactivated, and it overlaps the next column width cursor on its right side. It creates an issue because the next column on the right which has its cursor overlapped by the hidden price column width cursor is not usable... so it is impossible to modify the width of this column. The solution is to show the price scale column again to dissociate both cursors. |
| [2026-05-30 05:02:31] |
| Sierra_Chart Engineering - Posts: 25491 |
We will solve this: Also, on a DOM, when the price scale is hidden, the price scale width cursor never get deactivated, and it overlaps the next column width cursor on its right side. This will be solved in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-30 20:28:38
