Date/Time: Thu, 26 Nov 2026 04:57:44 +0000
pricesquawk activation request
View Count: 538
| [2026-05-29 13:45:10] |
| User816682 - Posts: 5 |
Hello I am trying to get pricesquawk on SC. I am told by pricesquawk that i have to request enablement from yourselves on here before setting up pricesquawk as a study. Appreciate any help with this. Also could you tell me can i be using two separate data feeds on my charts. I am using denali feed with teton routing to broker but pricesquawk can use standard dc feed when used as a study? Thanks Douglas. |
| [2026-05-29 15:17:26] |
We are sorry, but we can no longer setup enablements for Pricesquawk due to regulations from the exchanges. This changed several years ago, and we are surprised that Pricesquawk is stating that we can do this - we have not had this asked for in quite awhile. There is no way to get two separate data feeds into a single installation of Sierra Chart. In other words, you can not be getting your data from our Denali Exchange Data Feed and get data from dc feed (we do not know who "dc feed" is, do you mean DTN IQ Feed?). You can have two installations of Sierra Chart, one that is connected to Teton and Denali and another that is connected to DTN IQ Feed (or another data feed that we support). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-30 20:51:00] |
| blt - Posts: 235 |
... @User816682 If you set your Time&Sales sound alert in combination with filtering to desired sound ( in my case I opted for "bid" and "ask") you will get very accurate "sound image" of what's going on with the tape It is not as "fancy" as P$ but brings VERY good tape sentiment leonardo |
| [2026-06-01 10:38:22] |
Thanks for this, any good tips? I have imported two sounds i like into and assigned to alert 1 and alert 2. They are working pinging when bid or ask come onto tape at whatever I set the volume >= N. Using ES and NQ to trade MES at moment. Any advice appreciated but thanks for the reply anyhow. Douglas. |
| [2026-06-01 14:01:02] |
| blt - Posts: 235 |
... @User816682 You did good I think I text-generated "Bid"; "Ask" The same setting for Volume ">=" Set Volume to 10 ... You can play a lot around this If you really want to go nuts then Volume should be set to 1 Also play with "Combine..." Setting "Alerts" to NOT cross into previous one will have light lag but won't distort "the sentiment" of Tape Do not forget that SIERRA CHART did the smartest thing in industry-eliminating trades "between" that by def. do NOT exist (The Magic of DENALI) ... Enjoy leonardo |
