Date/Time: Thu, 26 Nov 2026 04:57:47 +0000
Volume by Price study only calculates current session — historical periods empty
View Count: 857
[2026-05-29 12:02:08]
User955425 - Posts: 2
Volume by Price (VBP) study only calculates the profile for the current session. Historical sessions show no profile drawn and POC reports 0.00 when hovering over historical bars, despite approximately 1,600 days of MNQ continuous tick data loaded on the chart.
Environment:
Sierra Chart version 2899
Data feed: Denali (SC Data - All Services)
Symbol: MNQ continuous futures, volume-based rollover, back-adjusted (chart shows MNQM26_FUT_CME [CBV] with Continuous Contract setting active)
Bar period: 5 Minute, Intraday Chart
Chart confirmed to contain ~1,600 days of data — Ctrl+Home navigates to a bar dated 2022-01-10
Symptom:
Only the current/most recent session shows a volume profile and non-zero POC/VAH/VAL
Scrolling to any historical date shows clean price candles with no horizontal profile drawn and no VAH/VAL/POC lines
Hovering over any historical bar shows "Point of Control: 0.00" in the chart header
Vertical Volume study works correctly across all historical bars (so historical volume data is present and readable)
VBP settings (relevant):
Draw Mode: Volume Profiles
Volume Graph Period Type: From Session Start Time to End
Number of Days To Calculate Volume Profiles: 1600
Minimum Time Period % For Reference Days Back: 0
Use Separate Profile For Evening Session: No
Start Time: 18:00:00, End Time: 17:00:00
Volume Bar Calculation Method: Total Volume
Value Area Percentage: 70
Extend Value Area: End Of Window
Extend Point Of Control: End Of Window
Chart Settings → Session Times:
Session Start Time: 18:00:00
Session End Time: 17:00:00
Use Evening Session: No
Apply Intraday Session Times To Intraday Chart: Yes
Time Zone: New York (-5 EST / -4 EDT)
Weekend Data: Load All Weekend Data
Chart Settings → Data Limiting:
Load Data Limiting Method: Use Number Of Days To Load
Days To Load for Intraday Chart Data Type: 1600
Date Range In File: 2025-04-09 to 2026-05-29 (415d range reported), however Ctrl+Home navigates to a bar dated 2022-01-10 — so actual loaded data extends well beyond the Date Range In File field's reported range
Troubleshooting already performed:
Reduced Number of Days To Calculate from 1600 → 10. No change. Profiles still only build for current session.
Changed Volume Graph Period Type from "From Session Start Time to End" to "One Period at End of Fixed Time Length - Auto-Skip Empty Days" with Fixed Time = 1 Day. No change.
Verified Minimum Time Period % For Reference Days Back = 0 (was originally 25, changed to 0, applied, persists).
Created duplicate chart with fresh VBP study using default settings (only Volume Graph Period Type changed). Same behavior — only current session profile drawn.
Checked Message Log — no VBP-related errors or warnings.
Confirmed Vertical Volume study calculates correctly for all historical bars, so the underlying tick/volume data is present and readable.
Question:
What configuration or data condition would cause VBP to silently skip all historical sessions while successfully building the current session profile, when Number of Days To Calculate is set to a value larger than 1 and the underlying chart contains the full historical data?
imagecurent day VP only.png / V - Attached On 2026-05-29 12:01:02 UTC - Size: 123.26 KB - 188 views
[2026-05-29 12:22:36]
User431178 - Posts: 910
Did you look at the instructions?
Volume By Price Study
This defines one Volume Profile at the last day in the chart that starts at the beginning of the trading day and goes through the last bar in the chart. The trading day is defined by the settings for Chart >> Chart Settings >> Session Times.
If you want multiple profile, then you need to choose one on the Multiple Profiles Based on options.
[2026-05-29 13:08:07]
Thank you! It works now.
