Date/Time: Thu, 26 Nov 2026 04:57:44 +0000
[Programming Help] - Connect Python script to Sierra Chart for automated spread orders
View Count: 727
[2026-05-29 10:48:15]
User579675 - Posts: 2
I have a Python script that reads real-time prices from Sierra Chart data files and calculates entry/exit signals for a 2-leg spread (ZFU26 + ZNU26). I need to connect this script to Sierra Chart to execute orders automatically.
What I tried:
DTC Protocol Server: Python connects successfully to port 11099, heartbeat is sent and acknowledged, but SUBMIT_ORDER messages are never executed. No orders appear.
Trading System Based on Alert Condition: tried FILE() formula but get #SYNTAX! error
Spreadsheet System for Trading: cannot link external CSV
My question:
What is the recommended way to have an external script trigger orders in Sierra Chart? Is DTC supposed to work with JSON? Or is ACSIL (C++) the only way?
Thank you.
[2026-06-01 21:00:52]
Sierra_Chart Engineering - Posts: 25491
You definitely can use the DTC Protocol server and connect a DTC Protocol client and submit orders through it. If you have an issue like this:
There must be some issue with the encoding. Yes JSON encoding can be used. Make sure each message is separated with a null character.
The easiest solution is to use ACSIL:
Automated Trading From an Advanced Custom Study
Date Time Of Last Edit: 2026-06-01 21:01:04
