Date/Time: Thu, 26 Nov 2026 04:57:41 +0000
Spread Order Entry - How to attach automatic TP/SL to spread orders?
View Count: 410
[2026-05-29 10:39:03]
User579675 - Posts: 2
I'm using the Trading Spread Order Entry study to enter 2-leg spread positions (ZFU26-CBOT + ZNU26-CBOT). The entry works fine, but I cannot get automatic Take Profit and Stop Loss to work.
What I've configured:
Use Target after Fill of Spread Entry: Yes
Use Stop after Fill of Spread Entry: Yes
Target Spread Price and Stop Spread Price are set
Use Attached Orders is enabled in Trade Window
Problem: When the spread entry triggers, no TP/SL orders appear in the Trade Window or on the chart. The position stays open until I close it manually.
Question: Is the Spread Order Entry study supposed to place attached TP/SL orders automatically? If yes, what am I missing? If no, what is the recommended method to automate both entry AND exit for spread orders in Sierra Chart?
I also tried DTC Protocol Server from Python, but orders are not executed despite successful connection and heartbeat.
Thank you for any guidance.
[2026-05-29 14:56:56]
You will not see an actual Target or Stop order line in the charts, as the Target and Stop are relative to the Spread, not the individual symbols. You should see the Target and Stop showing in the region that has the "Spread Order Entry" graph.
[2026-05-31 10:42:23]
User592284 - Posts: 4
Vous ne verrez pas de ligne d'ordre Target ou Stop directement sur les graphiques, car ces ordres sont relatifs au Spread et non aux symboles individuels. Vous devriez les voir apparaître dans la zone affichant le graphique « Saisie d'ordre Spread ».
Merci pour votre réponse. Cependant, les ordres Target et Stop ne se déclenchent pas automatiquement. Même quand je les configure et que le prix atteint le target, la position ne se ferme pas. Je dois clôturer manuellement à chaque fois. Pourquoi le Target et le Stop ne déclenchent-ils pas une sortie automatique ?
Thank you for your answer. However, the Target and Stop orders are not executing. Even when I set them and the price reaches the target, the position does not close. I have to manually flatten every time. Why are the Target/Stop not triggering an automatic exit?
[2026-06-01 16:01:19]
User592284:
You have posted from an expired account. If you have an active account, then we need for you to post from that account.
