Date/Time: Thu, 26 Nov 2026 04:57:46 +0000
Unable to add to Study Summery Window
View Count: 416
[2026-05-28 18:49:04]
User740709 - Posts: 159
For some unknown reason, I am unable to add the subgraphs from your study called Daily OHLC to the Study Summery Window.
I follow the instructions on your help page Study Summary Window but this one fails and does not add any values. Other studies work.
Could you look into it?
Thanks.
BR
[2026-05-28 19:18:20]
Please get us an image of the "Study Summary" window.
Is the "Daily OHLC" study hidden, or any of the main subgraphs that you want to see in the Study Summary hidden?
[2026-05-29 12:20:33]
Thanks!
Here is the screenshot of the Study Summary Window and the settings of the Daily OHLC study.
You can see that the study is not hidden and is included in the SSW on both the Settings tab as well as Subgraphs tab.
But even if it was hidden, there is a setting to display hidden studies in the Study Summary and it works fine.
Regards,
H.
imageSSW.png / V - Attached On 2026-05-29 12:19:47 UTC - Size: 218.97 KB - 179 views
[2026-05-29 15:01:27]
Please get us the Chartbook that has that chart in it so we can take a look. Follow these instructions to get us the chartbook:
[2026-05-29 15:16:56]
Thank you.
After I tried to add another study, it started to work without me doing anything.
I will let you know if anything changes.
Thanks.
Kind regards,
H.
