Date/Time: Thu, 26 Nov 2026 04:45:52 +0000
Number Bars issue
View Count: 464
[2026-05-28 09:36:58]
User123816 - Posts: 11
I am trying to add Number Bars on my chart. Read the instructions on the website. But, when i apply it, it doesnt't show up and the candlestick chart is gone too. Everthing goes blank.
Please help. I mention that I'm using service package 10.
Thanks,
[2026-05-28 09:45:47]
User431178 - Posts: 910
You need service package 11 for number bars
Description of Service Packages and Pricing: Integrated Packages
[2026-05-28 13:08:06]
Sierra_Chart Engineering - Posts: 25491
First, we recommend that you update Sierra Chart to the current version. You are running a significantly older version. Newer versions make it clear when you add that study, what the problem is.
Instructions to update:
We have given you a free trial of the highest service package for the next 30 days for you to have access to Numbers Bars for the time being.
After that you will need to change to Service Package 11 but there is nothing that you need to do now:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
Date Time Of Last Edit: 2026-05-28 13:10:05
