Date/Time: Fri, 06 Nov 2026 12:56:00 +0000
Automatic Position Sizing for the Trade Window [Feature Request]
View Count: 531
[2026-05-27 20:08:28]
Deenius - Posts: 167
Would it be possible to add an automatic position sizing calculation feature to the Trade Window?
Some other trading platforms, such as TradingView, offer this as a standard feature (see screenshot). So it would be a shame if Sierra Chart fell behind in this regard.
I spent several hours searching the support board and found that there is a huge demand for this. However, no one has requested implementation yet.
I found that some users have developed their own solutions. However, these are often imperfect and have various limitations. I believe that you would certainly offer a much more sophisticated and well-thought-out solution. In any case, I’m adding a list here in case anyone is interested.
https://tradingedgeresources.gumroad.com/l/positionsizing
https://orderflowtriggers.gumroad.com/l/executor
https://www.scstudies.com/products/trade-manager
https://polaristradinggroup.com/products-page/indicators/position-sizer-reward-risk-tool/
https://forgivingcomputers.com/product/risk-based-futures-position-sizer/
https://noesisanalytics.io/margin-9
Just for inspiration, this is the Trade Panel I’ve been using for MetaTrader for a long time. It’s really well-designed.
https://www.mql5.com/en/market/product/35049?source=Unknown
Thank you for considering my suggestion.
imageTradingView - Position Sizing.jpg / V - Attached On 2026-05-27 19:54:46 UTC - Size: 733.44 KB - 182 views
[2026-06-04 01:34:55]
Adjoua24 - Posts: 6
I’ve been looking into position sizing solutions for Sierra Chart recently as well.
One thing to keep in mind is that this has been requested by users for quite a long time already. There are multiple discussions on the support board about risk-based sizing and position calculators, but it doesn’t seem to be a feature that’s currently high on Sierra Chart’s development priorities.
In the meantime, one option that hasn’t been mentioned much yet is Margin-9. It’s relatively new compared to some of the other tools, but from my experience it is quite professionally built, robust, and well documented.
The setup process can be a bit complex at first (somewhat similar to Sierra Chart itself), but the upside is that it offers a lot of flexibility once everything is configured properly. I also found their support team to be very responsive whenever I ran into issues.
That said, it isn’t perfect. At the moment it doesn’t support market-order based execution, and it’s also on the more expensive side compared to some alternatives.
From what I’ve heard, they’re working on a major update that should expand order support and make the setup process much easier.
For now, I’d say it’s definitely worth a look if advanced risk-based position sizing is important to you. Otherwise, it may be worth waiting for the next major release, her:
https://noesisanalytics.dev/releases/margin-9
Good luck!
[2026-06-11 06:21:16]
Adjoua24 - Posts: 6
Just as a follow-up to my previous post: I noticed that Margin-9 recently released a fairly major update.
One of the drawbacks I mentioned earlier was the lack of market-order support, which seems to be available now.
They also reworked parts of the setup and order handling.
[2026-06-11 11:38:49]
Hello Sierra Chart team,
Two weeks ago, I requested the feature described above. Unfortunately, none of you has responded yet.
Could you please let me know if you will consider my suggestion?
Automatic position sizing is a really useful feature for day-to-day trading and would make our work much easier. Thank you.
[2026-06-11 14:37:36]
This has been noted as a Feature Request.
We can not say when we would get to any particular request.
