Date/Time: Thu, 26 Nov 2026 04:45:49 +0000
direct api data feed connections for cloud services
View Count: 247
[2026-05-27 15:44:57]
kod7 - Posts: 1
Hello
Are your feeds valid for 24/7 headlesss use and can support api connection from cloud virtual machines?
Also which feed is the best for this kind of purpose or all support it?
The cloud service will need direct api connection to live data feeds
[2026-05-27 16:16:48]
No. The data we get from the exchanges is Display Only. So it can not be used outside of the Sierra Chart software.
No idea. You will probably need to get the data directly from the exchange for this, which is quite expensive.
