Date/Time: Thu, 26 Nov 2026 04:45:49 +0000
Is Is Possible To Remove The PL Text from the Active Order Line?
View Count: 312
[2026-05-26 15:56:46]
jsandlan - Posts: 99
I have removed the actual P/L from the top left of the chart and the actual P/L from the active Order Line but I still see the literal "P/L:" text itself and I'm wondering if it's possible to remove that text.
To be clear, I'm not talking about the open profit / loss.
I'm referring to the actual text that shows "P/L:" i.e. capital letter P followed by a forward slash followed by capital L etc.
Thank you.
Date Time Of Last Edit: 2026-05-26 16:01:32
imagePL.png / V - Attached On 2026-05-26 15:56:06 UTC - Size: 35.63 KB - 107 views
[2026-05-26 16:59:50]
You have not removed the P/L display from the Position line. In the image you show, you have a P/L of 0.00038 Points. Refer to the following:
Global Trade Settings Windows: Display Profit/Loss On Position Line (Global Settings >> Chart Trade Settings >> General >> Trade Position Line)
Also refer to the following setting that should be set to "None" for each of your charts for what you are wanting:
Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu)
[2026-05-26 17:05:06]
Hi John, that image is just a stock image from the Sierra Chart docs. The P/L on my charts is no longer visible but I still see the text "P/L:" with nothing after it on the Order Line. Is it possible to remove that text?
Thanks.
Date Time Of Last Edit: 2026-05-26 17:05:34
[2026-05-26 17:29:06]
If you set the option for "Display Profit/Loss on Position Line" to "No", then the "P/L:" should not be displayed.
Please get us an image of what you are actually seeing.
[2026-05-26 19:00:53]
Thanks John.
Setting Display Profit/Loss On Position Line to No in Global Settings -> Chart Trade Settings -> Chart Position Line worked to hide the raw P/L text from the Order Line.
Date Time Of Last Edit: 2026-05-26 19:01:58
