Date/Time: Thu, 26 Nov 2026 04:45:51 +0000
Alternative to interactive brokers
View Count: 351
[2026-05-25 12:08:05]
kero kero - Posts: 8
I want to understand what are the alternatives to "Interactive Brokers".
As i understand i subscribe to a data feed and pay monthly sierra fees right?
But what legit solutions exists to replace "Interactive Brokers" which is my current API, then i'ld like to remain on the Denali Data Feed.
How can i do that? And what are the alternatives options to IKBR?
Best regards,
Edin.
[2026-05-26 14:36:29]
Sierra Chart has support for trading directly with Interactive Brokers, or brokers that support the use of CQG (verify with broker), Rithmic, or Teton for their order routing. Refer to the following:
Supported Data and Trading Services: Supported Services
If you are just trading the CME Group, then we recommend finding a broker that supports our Teton Order Routing service. You will find a list of these brokers at Step #2 at the following link:
Sierra Chart Teton Futures Order Routing: Setup Instructions
