Date/Time: Thu, 26 Nov 2026 04:57:47 +0000
Trade Dom Profile ETH vs RTH
View Count: 497
[2026-05-22 14:43:45]
User171803 - Posts: 3
So I have my profile on the dom and right now it is on session start to end which is the start of ETH at 8 to end of RTH at 7. I was wondering if it was possible to have it start at 8 at globex open and go through to the start of the day session where it then resets and starts a new profile. I know I can do this on the chart with multiple profiles based on fix times but cant select that on Dom. Thanks
imageSession times.png / V - Attached On 2026-05-22 14:43:17 UTC - Size: 5.69 KB - 180 views
[2026-05-22 15:32:14]
Use a "Volume Graph Period Type" of "From Start Time to End", and set your "Start Time" to 08:00.
[2026-05-23 02:30:48]
I dont think this accomplishes what im after. I want it to create seperate profiles for ETH and RTH, so the first profile from 8-23:30 and then reset and start a new profile at the beginning of RTH and go to 7. This is what my session times are set to but im not sure what profile setting can accomplish this on the dom.
[2026-05-26 14:18:28]
For what you want, set the "Volume Graph Period Type" to "Trading Day Start Time to End - Reset at Day Session". Refer to the following:
Volume By Price Study: Trading Day Start Time to End - Reset at Day Session
[2026-05-27 14:10:01]
Okay that worked, but now im having trouble again. So it resets at the start of the day session which is set to 23:30 in the session times which is great, however its also resetting during the session at 0:00:00 my time which I dont have set anywhere in my settings.
imageSession times.png / V - Attached On 2026-05-27 14:09:40 UTC - Size: 24.19 KB - 108 views
imageStudy settings VBP.png / V - Attached On 2026-05-27 14:09:51 UTC - Size: 29.21 KB - 134 views
[2026-05-27 15:37:01]
Sorry, historically most of the options for the Volume by Price are not allowed on the Trading DOM, so you typically can only use the option for "One Period at End of Fixed Time". We see that other options have been made available, but we also see that the option for "Trading Day Start Time to End - Reset at Day Session" is not working properly.
We will have to look into this and determine what is occurring in the Trading DOM for this.
In the meantime, the only workaround would be to use "From Start Date-Time to End" and set the Date and Time to what you want to show at that time. You would have to change it when you want to reset between day and evening sessions.
[2026-06-01 23:46:42]
Sierra_Chart Engineering - Posts: 25491
This will be solved in the next release. This issue is not specific to a Trade DOM.
