Date/Time: Thu, 26 Nov 2026 04:45:50 +0000
Display NQ on Chart Trade MNQ?
View Count: 610
| [2026-05-21 14:50:00] |
| DualADX - Posts: 41 |
I want to trade MNQ but have NQ displayed on the trading chart. I'm pretty sure this can be done with the 3 settings in my picture but I forgot exactly how and I cannot find the documentation/directions.
| [2026-05-21 16:58:59] |
Set the "Trade and Current Quote Symbol" to be the required symbol for your trading service for MNQ. Refer to the following: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) How you set the "Use as Trade Only Symbol" depends on how you want to view specific information. Refer to the following regarding this: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) And don't forget to change the "Currency Value per Tick" as noted in the section for the Trade and Current Quote Symbol. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
