Date/Time: Thu, 26 Nov 2026 04:45:49 +0000
Clarification on ACSIL Drawing Tool Functions in Integrated Advanced MBO Build
View Count: 394
[2026-05-20 12:39:00]
Marexmah - Posts: 4
Hi, I’m on Service Package 12 – Integrated Advanced MBO and using a clean installation of Sierra Chart.
When compiling a custom study that uses the standard ACSIL drawing‑tool functions:
sc.GetUserDrawnDrawingsCount()
sc.GetUserDrawnChartDrawing()
the compiler returns:
“error: too few arguments to function”
This happens even after a full clean reinstall, with the default ACS_Source folder and headers restored.
Can you confirm whether the Integrated Advanced MBO build includes support for these drawing‑related ACSIL functions, or if they are only available in the Main (non‑MBO) Sierra Chart build?
many thanks
Damien
[2026-05-20 13:06:43]
User431178 - Posts: 910
No difference in ACSIL between packages.
That means something is wrong in your code.
How are you calling those functions?
sc.GetUserDrawnChartDrawing takes 4 arguments
sc.GetUserDrawnChartDrawing(int ChartNumber, DrawingTypeEnum DrawingType, s_UseTool& ChartDrawing, int DrawingIndex);
GetUserDrawnDrawingsCount takes 2 arguments
sc.GetUserDrawnDrawingsCount(int ChartNumber, int ExcludeOtherStudyInstances);
[2026-05-20 14:04:44]
Marexmah - Posts: 4
thanks.. i didn't have the correct arguments.. much appreciated!
