Date/Time: Thu, 26 Nov 2026 04:45:45 +0000
DELTA VOLUME AND CUMULATIVE DELTA VOLUME IN DAILY CHART
View Count: 366
| [2026-05-19 17:12:38] |
| User492182 - Posts: 1 |
HI. I HAVE THE 12 PACK AND USE THE DENALI EXCHANGE DATA FEED (NASDAQ TOTALVIEW), I CAN USE DELTA VOLUME AND CUMULATIVE DELTA VOLUME IN INTRADAY CHART BUT THOSE DO NOT APPEAR IN DAILY CHART. I DO NOT KNOW IF I HAVE CHANGED SOMETHING IN SETTINGS OR IF I HAVE TO PAY SOMETHING MORE FOR THAT DATA. THANKS VERY MUCH.
| [2026-05-19 17:59:24] |
Daily data is very different from the Intraday data. Daily data is just the Open/High/Low/Close/Volume information for the day. There is no bid/ask information, so there is no way to generate the Delta and Cumulative Delta from daily data. If you want to have a daily bar that has this information, then you have to force the system to use the Intraday Data for a 1 day or higher timeframe. To do this, set "Chart >> Chart Settings >> Data Limiting >> Chart Data Type" to "Intraday Chart Only". Refer to the following: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
