Date/Time: Thu, 26 Nov 2026 04:45:47 +0000
Create Manually Trading Stop while in a trade
View Count: 271
| [2026-05-18 16:28:26] |
| User672758 - Posts: 8 |
Hi Sierra Chart. I am trading on SC with an atm on the DOM. My data provider is SC, my broker is APEX (Rithmic.) The atm is set to create a stop I can manually trail when I hit a certain profit. Is there a way to create a stop that trails "on the fly" in the DOM? A few times I have accidentally closed my stop and wanted to create a stop that I could trail while I was in the trade. Thanks!
| [2026-05-18 21:19:22] |
A Trailing Stop is available as an Order Type, along with a few other options similar to it (such as a Step Trailing Stop). Refer to the following and the items below it: Order Types: Trailing Stop To actually put that Stop in associated with the parent order, you would need to use one of the "Send Attached Orders by Position/Price" order types. Refer to the following: Order Types: Send Attached Orders - Position/Price For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
