Date/Time: Thu, 26 Nov 2026 04:45:50 +0000
Another TPO profile chart question
View Count: 323
[2026-05-16 17:34:55]
User922418 - Posts: 42
Is it possible to color code the 15 minute, or 30 minute BARS (or whatever time frame the bars are set to) in Letters/Blocks in own Column and Standard Profile to green and or red?
Just using the open and close to determine the color of the bar.
If this is not available to do in the current software release, could you please make this available in the next software release update?? Would REALLY like to see this. Would save me from having to look at the regular bar chart and figure out how that applies to the TPO profile chart.
Thank you
[2026-05-18 15:09:01]
We have noted this as a Feature Request.
We can not say when we would get to any particular request.
We do want to point out that there is the option for "Highlight Open of Each New Sub Period Within TPO Profile". You can then use this as an indicator directionality of the bar by comparing the next sub-period's Open to the current sub-period Open, since most of the time the Open of the next period is the same as the Close of the current period.
[2026-05-18 16:02:39]
Hey John
You taught showed me something I didn't see before.
Is there a way to get that highlighted open for each sub period in the Subgraph(s) section, so I could then get a horizontal line with value label???
[2026-05-18 21:16:46]
Sorry, the information for the Sub-Period Open is not available in a Subgraph, or through any other means.
