Date/Time: Mon, 09 Nov 2026 05:05:40 +0000
The Erase Drawing Mode Feature Does Not Respect My Tool Settings
View Count: 467
| [2026-05-16 17:08:39] |
| Deenius - Posts: 170 |
Hello, I have Sierra Chart configured so that right-clicking switches the current drawing tool to the hand tool. When I use the Erase Single Drawing feature, everything works as it should. However, when I use the Erase Drawing Mode feature, right-clicking switches to the pointer tool instead of the hand tool (please see the video). https://youtu.be/MTT9r2KqSI8 Could you please look into this? Thank you. |
| [2026-05-20 13:37:33] |
| Sierra_Chart Engineering - Posts: 25404 |
We will check on this.
| [2026-06-15 14:05:11] |
Hello, I just wanted to ask if this issue will be solved? Date Time Of Last Edit: 2026-06-15 14:06:28
| [2026-06-16 21:53:17] |
Support for what you are looking for will be implemented in the next release. The erase drawing mode is not really considered a tool. So this setting does not apply but will in the next release: Tool Settings >> General >> Tool Options >> Right Click Exits Current Drawing Tool To : "None" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-06-17 05:48:10] |
Thank you very much. I really appreciate it.
| [2026-06-23 07:07:42] |
Hello, I tested the feature and ran into a problem. After I use Erase Drawing Mode, Erase Single Drawing switches to the pointer tool instead of the hand tool, which is how I have it set up. Please take a look at the video. https://youtu.be/soKrMHROYdc |
| [2026-06-24 21:50:35] |
We are checking on this.
