Date/Time: Thu, 26 Nov 2026 04:45:51 +0000
Redistributing Custom Studies
View Count: 513
| [2026-05-15 20:22:49] |
| fcws - Posts: 2 |
Hi, I have followed all of the instructions for allowing users that we add to our custom studies list from our account control panel. We are using the sc.IsUserAllowedForSCDLLName function in our studies to check that the user has access. However, no matter what we do, all of our studies produce the "Your account doesn't have access" error (based on what we set to log in the message log if the sc.IsUserAllowedForSCDLLName returns false). The studies are automatically downloaded to the user's system (into their data folder), so there accounts are given access, but the protection of the DLL file with the sc.IsUserAllowedForSCDLLName fails. Not sure what we are missing/doing wrong, but if you can shed any light or point me in the correct direction, we'd really appreciate it!
| [2026-05-15 20:50:48] |
| Sierra_Chart Engineering - Posts: 25491 |
In the source code of the studies which use sc.IsUserAllowedForSCDLLName , what is this line set to?: SCDLLName("")
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-15 20:51:31
| [2026-05-16 14:24:18] |
| fcws - Posts: 2 |
For the test, the SCDLLName is literally: TEST Here's the exact code that I am using (this is the test from the documentation). Once I figure out how to get it working, I will update our other studies: #include "sierrachart.h" SCDLLName("TEST") //This function is an example of using the sc.IsUserAllowedForSCDLLName variable SCSFExport scsf_IsUserAllowedForSCDLLNameExample(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "IsUserAllowedForSCDLLName"; sc.StudyDescription = "This function is an example of using the sc.IsUserAllowedForSCDLLName variable to protect a study."; sc.AutoLoop = 1; return; } // Do data processing if(sc.IsUserAllowedForSCDLLName == false) { if(sc.Index == 0) { sc.AddMessageToLog("You are not allowed to use this study",1); } return; } } |
| [2026-05-19 14:29:13] |
First choose some other longer and more unique name for the custom studies DLL: SCDLLName("TEST")
For example, use SCDLLName("Test20260519") And that name has to be added here: https://www.sierrachart.com/UserControlPanel.php?page=ManageCustomStudiesDLLUsers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-19 14:29:39
