Date/Time: Thu, 26 Nov 2026 04:33:44 +0000
Error installing sierra chart in parallels
View Count: 313
| [2026-05-15 15:28:07] |
| User545800 - Posts: 15 |
Hi, getting error "Failed to create folder: SierraChart\DownloadedInstallationFiles\ACS_Source\. CreateFolderRecursively: Windows error code 3: The system cannot find the path specified." and much more following this error while installing sierra chart in parallels. Attached is the log file. Seared in support forum and unable to find relevant requests to help resolve.
Private File |
| [2026-05-15 15:42:41] |
| Sierra_Chart Engineering - Posts: 25491 |
Use the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
