Date/Time: Thu, 26 Nov 2026 04:33:41 +0000
do u have some free algo open source ??
View Count: 303
| [2026-05-14 23:18:50] |
| SRTARDR - Posts: 3 |
do u have some free trading algo open source , maybe it will help. i finished my claude.ai in 2 days i did 42 versions . of very simple algo logic ,( enter at entry level and move sl at next 5 tps reached ) (starttime _flatclosetime) . after 42 attempt i failed and ifinished my claudemoney need to pay more . do u offer any help ?? don t u have 100s of free opensource algos like ninjatraedr, claude can learn understand from them??
Date Time Of Last Edit: 2026-05-14 23:19:58
| [2026-05-15 14:42:56] |
| Sierra_Chart Engineering - Posts: 25491 |
Refer to: Example ACSIL Trading Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
