Date/Time: Thu, 26 Nov 2026 04:33:42 +0000
Easy Solution to pay non-professional CME fees
View Count: 293
| [2026-05-14 21:21:45] |
| lorenzo62 - Posts: 4 |
Hi, Would the 'easy solution' also work with an account opened at AMP Futures? Thank You |
| [2026-05-15 13:32:23] |
Hi, Forgot to mention that I need to do this to prop firm trade my test account with Lucid Trading so I get live streaming data with no delays. Thanks |
| [2026-05-15 13:44:50] |
| Sierra_Chart Engineering - Posts: 25491 |
Yes for sure: Would the 'easy solution' also work with an account opened at AMP Futures? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-15 14:07:21] |
Thank You!
