Date/Time: Thu, 26 Nov 2026 04:33:44 +0000
need help make algo
View Count: 258
[2026-05-14 21:20:56]
SRTARDR - Posts: 3
last question i was able find answer by hardcoding timing inside algo.as i saw the backtest doesn trespect chart timeperiod. so that thing of using the correct timeperiod solved. but now am running into 32nd version of algo . and i still did not make one buy . algologic is very easy enter at entrypoint and keep moving sl at each tp reached . start and shut at certain hour defined . it s very simple logic yet after 32 version am unalbe to create even a buy or sell. price moves by those levels but does nothing. do u provide help or not?? such a thing ai created it with ninjatrader after 3 attempts only.
Date Time Of Last Edit: 2026-05-14 22:07:31
[2026-05-15 15:18:58]
Sierra_Chart Engineering - Posts: 25491
Refer to:
Automated Trading Management: Troubleshooting Automated Trading System Behavior
This does not make sense to us:
Back testing will be back testing the data in the chart, and certainly the chart session times, and the chart bar period, will absolutely be followed. There simply is no other possibility.
