Date/Time: Fri, 06 Nov 2026 12:52:52 +0000
Target Attached Order Tick-Up or Down - Pending vs. Active Order
View Count: 279
[2026-05-14 17:25:38]
DCSaba - Posts: 124
It would expand Sierr's trading abilities if it would differentiate between Targets that are already active and those that are still pending entry.
When using the Keyboard shortcut called "Target Attached Order Tick-Up or Down" I constantly run into the issue of Sierra moving a still-inactive Target order instead of the nearby active Taget order, just because the inactive one is closer to the current price.
Since in these moments price is very near the level where the Active Order is, in these situations the inactive Target Order is of no importance, yet that is the one that moves, while the Active one doesn't and therefore oftentimes does not get a fill as a result.
Could you make such changes, so that inactive ORders do not react to this Keyboard SHortcut when they are not visible (turned off from visibility by the option "Hide Pending Attached Orders")?
This would be really helpful.
Thank you.
[2026-05-14 17:27:47]
We have noted this as a Feature Request.
We can not say when we would get to any particular request.
[2026-05-15 13:47:30]
Sierra_Chart Engineering - Posts: 25390
Yes we will work on this:
This will be out in the next release.
Date Time Of Last Edit: 2026-05-15 13:58:27
[2026-06-13 13:36:30]
DCSaba - Posts: 124
You did it!
You are brilliant!
Thank you so much!
