Date/Time: Thu, 26 Nov 2026 04:33:46 +0000
calcualtion question
View Count: 272
| [2026-05-13 16:33:45] |
| coachted - Posts: 545 |
So i am comparing my closed trades' profit and closed trade loss from the statistics page to the trade page of the trade activity tab... I have discovered the statistics profit is $10 higher and the statistics loss is $10 low compared to manually calculating them. Please advise
| [2026-05-14 22:39:17] |
| Sierra_Chart Engineering - Posts: 25491 |
Possibly it is related to the commission. Remove the commission and see if you notice a difference. And the other thing we want you do is disable on the Trades tab is Edit >> Flat to Flat Display for Trades. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
