Date/Time: Thu, 26 Nov 2026 04:33:49 +0000
Numbers Bars — How to set cluster size (price increment) to 0.0002 for 6E futures
View Count: 435
| [2026-05-13 10:52:48] |
| Leon1123 - Posts: 8 |
Hello, I am using Sierra Chart with the Denali data feed for backtesting purposes on the Euro FX futures (6EH25-CME) with a 1-minute intraday chart. I have added the Numbers Bars study to display bid x ask volume at each price level. However, I would like to set the cluster size (price increment per row) to 0.0002, which represents 4 ticks on the 6E and gives a clean, readable footprint for my analysis on M1. The default tick size of the symbol is 0.000050, which makes the footprint too granular and difficult to read on a 1-minute chart. I have tried to find this setting inside the Numbers Bars study inputs but the list starts at Input 16 and I cannot scroll up to access the earlier inputs where I believe the Round Price To Increment parameter should be located. Could you please tell me where exactly I can find and modify this parameter, and whether there is an alternative way to set the cluster size for the Numbers Bars study? Thank you very much for your help. |
| [2026-05-13 14:29:58] |
The way to do this is to change the "Volume by Price Multiplier" for the chart. There is not a setting within the Numbers Bars study itself that does this. Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
