Date/Time: Thu, 26 Nov 2026 04:33:39 +0000
AMP Futures with Sierra Chart Teton and Non-Professional Denali verification
View Count: 1135
| [2026-05-13 03:39:41] |
| Mr.Dilik - Posts: 1 |
Hello Sierra Chart Support, I am planning to open a futures trading account with AMP Futures and use: Sierra Chart + Denali Data + Teton Order Routing AMP confirmed that they support Sierra Chart Teton Order Routing for MES and MNQ. Before I proceed with opening the account, could you please confirm the following: 1. Will a live funded AMP Futures account satisfy the CME non-professional verification requirement for Sierra Chart Denali data? 2. If I classify myself as Non-Professional for CME data, will AMP be an acceptable broker/clearing connection for maintaining my Sierra Chart Denali CME non-professional data status? 3. Do I need to connect Sierra Chart to the live funded AMP account once per month for non-professional verification, or is this handled automatically when using AMP with Teton? 4. With AMP + Teton, are server-side bracket orders and OCO orders supported in Sierra Chart? 5. For the Teton setup with AMP, should I select: Global Settings → Data/Trade Service Settings → Current Selected Service → Teton CME Order Routing and then choose AMP as the clearing firm? 6. If I use Sierra Chart Denali data, do I need any separate market data subscription through AMP, or is Denali enough for real-time CME/MES/MNQ data? 7. Is there anything specific I should tell AMP when opening the account so they can correctly link the trading account to my Sierra Chart username? Thank you. Best regards, Dilshod |
| [2026-05-13 09:10:59] |
| Rui S - Posts: 258 |
Mr.Dilik, That's a yes for all your questions except #6, which is a "no". It´s an easy process. Good luck! |
| [2026-05-13 14:02:36] |
As Rui S states, the only item that is "No" is the need to setup data with AMP. But their selection for Teton already has this as part of the option. The only item you need to ensure that you give to AMP correctly is your Sierra Chart Account Name. Your redacted Account Name is the following: m*********4 The instructions for setting up the Teton Order Routing service is here: Sierra Chart Teton Futures Order Routing: Setup Instructions In the above instructions, step #5 has you setup the Denali Exchange Data Feed. You MUST do this in order to get the real-time data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
