Date/Time: Thu, 26 Nov 2026 04:33:46 +0000
Data feed with AMP futures and Sierrachart
View Count: 479
| [2026-05-11 15:20:23] |
| User210821 - Posts: 9 |
Hello I have bought service package 11 and tomorrow I will try to login with my Amp futures account. Is there any specific thing which I have to do to be able to use Denali Exchange Data Feed.
| [2026-05-11 17:24:38] |
There are still two things you need to do: 1. Redo the exchange agreements for the CME Group. When you filled these out you did not enter a Clearing Firm or Account Number. Since you state that you have an account with AMP, you will need to enter "AMP" for your Clearing Firm and enter your appropriate Account Number. You can access the agreements at the following link: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements_CME 2. Connect your Sierra Chart software to your AMP account. Once you make a good connection, then your "Verified Until" date will change to 30 days in the future. This date must be in the future in order to receive the real-time data for the CME Group. You can view this date at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
