Date/Time: Thu, 26 Nov 2026 04:33:50 +0000
files on startup path wrong
View Count: 239
| [2026-05-11 10:35:51] |
| tomas262 - Posts: 164 |
I sometimes copy SC instances to transfer settings and just change broker / provider Now I encounter a strange bug where the path to the data folder seems obsolete See the screenshot attached Despiste the data folder path is set correctly under 'Paths' SierraChart still refers to old location where I copy the instance from. So if I want to choose files for the startup SC remembers the path from previous location and show incorrect file Date Time Of Last Edit: 2026-05-11 10:36:52
| [2026-05-11 14:38:03] |
This would be the case, as you are copying the settings from another instance. You would need to remove all the currently listed items to be automatically opened, and then change the folder to find the appropriate files for that particular installation.
