Date/Time: Thu, 26 Nov 2026 04:33:48 +0000
Problem: Quoteboard visible across chartbooks
View Count: 247
| [2026-05-11 07:02:19] |
| ticinotrader - Posts: 431 |
Dear Support, I found a problem when opening multiple chartbooks containing a quoteboard. It happens with all versions starting from 2888 (not sure about earlier versions): After restarting Sierra Chart and opening multiple chartbooks at once using Multiple Selection, a Quoteboard window can incorrectly appear across all chartbooks. This happens if one of the opened chartbooks contain a Quoteboard. The Quoteboard does not display its actual symbol/content data initially, but the window itself is visible on all chartbooks. The option “Visible Across All Chartbooks” is disabled for the Quoteboard. The Quoteboard remains incorrectly displayed across all chartbooks until I manually select the chartbook that actually owns the Quoteboard. Once I activate/select the original source chartbook, the Quoteboard immediately behaves correctly again and only appears on its assigned chartbook. Before selecting the source chartbook, the Quoteboard menu items are inactive/un-clickable. This behavior appears reproducible when opening multiple chartbooks simultaneously during startup. Attached screenshots for reference. |
| [2026-05-11 07:22:48] |
| Sierra_Chart Engineering - Posts: 25491 |
Thank you we will check on this.
