Date/Time: Thu, 26 Nov 2026 04:33:48 +0000
Global data feed is disabled
View Count: 234
| [2026-05-11 06:40:22] |
| User754127 - Posts: 1 |
Hi team, My account sreerow in trail period, I'm from India, looking for global data feed to be enabled for my account. Could you please do the needful at the earliest. Thanks, Sreekanth |
| [2026-05-11 14:42:30] |
You can not connect to any trading or data services while on a Trial. If you want to connect to Global Data Feeds, then you will need to change a paid package. And you need to be on one of the "Integrated" packages in order to be able to connect to data and/or trading services. Refer to the information for the packages at the following link: Description of Service Packages and Pricing: Packages To change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
