Date/Time: Thu, 26 Nov 2026 04:33:46 +0000
Images won't upload
View Count: 260
| [2026-05-11 05:46:13] |
| User359632 - Posts: 8 |
Trying to attach images of your broken software, but images won't upload.
| [2026-05-11 06:18:18] |
| Sierra_Chart Engineering - Posts: 25491 |
Did you want to provide an image of a chart? If so, here are instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) What exactly is the issue you are having with Sierra Chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-11 06:21:53
| [2026-05-11 06:31:38] |
I can't see a current chart
| [2026-05-11 16:51:01] |
What is the setting for "Chart >> Chart Settings >> Symbol >> Symbol"? And also, what is the setting for "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service"? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
