Date/Time: Thu, 26 Nov 2026 04:45:54 +0000
SIERRA CHART ver. 2905 (problem with setting DOM)
View Count: 445
| [2026-05-11 02:13:35] |
| blt - Posts: 235 |
... To: Wizards of SIERRA CHART FYI Just uploaded prerelease 2905 from 2904 My DOM (as separate standing) came up with scrambled colors Tried to set/adjust colors of my choice as in ver. 2904-couldn't do it !!! Many other adjustments in MDI do not function (vol. bars-can't get any; etc.) Colors in "Value" column do not match choice you set Some works fine ... Please let me know am I doing something wrong; is there a new" way of adjusting those Went back to 2904-all perfect Thank you |
| [2026-05-11 02:48:56] |
| Sierra_Chart Engineering - Posts: 25491 |
We are aware of a problem related to this and will be putting out a new release in 1.5 hours.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-11 02:49:19
| [2026-05-11 02:59:26] |
| blt - Posts: 235 |
... I am really worried you guys will crack under pressure of such out of this world dedication and professionalism to your customers Thank you so much for your way of doing business |
| [2026-05-11 05:20:40] |
Nothing to be concerned with. We apologize for the delay. We have released version 2906. Please update to that when you have a chance, and let us know that the problem is resolved.
| [2026-05-11 07:23:36] |
| bozo_j - Posts: 51 |
FYI Version 2904 is still the one being downloaded when using Help -> Download Current Version |
| [2026-05-11 07:57:30] |
To get version 2906, you need to use Help >> Download Prerelease.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-11 07:57:51
| [2026-05-11 14:02:15] |
| blt - Posts: 235 |
... REPORT: DOM (separated standing) works to PERFECTION !!! Thank you ... ... NOTE: Still can't see that BUTTON in ACCOUNT MANAGEMENT for SHOWING APPRECIATION (voluntary) coming from your customers !!! Begging you to create such Do not make me look like psycho hitting you with that "request" every time you do your magic 🧝♂️...please You are NOT "normal" Co. Again you are so bloody unique in EVERY aspect of your business (any business) Thank you thank you thank you Leonardo |
| [2026-05-25 04:32:17] |
Thank you for your comments!
