Date/Time: Tue, 20 Oct 2026 14:24:51 +0000
[User Discussion] - Auto spreader Spread trading
View Count: 359
[2026-05-09 21:42:13]
User601016 - Posts: 31
Hi!
Can you please provide easier, faster and practical solution to TT Auto spreader on a DOM and show corresponding spread chart? The spread trading currently in SC is not the right solution for discretionary trader in fast moving markets.. Below are the details
Thank You!
TT DOM spread trading means using TT’s **Autospreader/MD Trader** workflow to trade synthetic futures spreads from the ladder, instead of trading a single outright contract. [tradingtechnologies](https://tradingtechnologies.com/trading/spread-trading/)
## How it works
TT supports exchange-listed or user-defined spreads, and you can trade them as price differentials, ratios, net change in ticks, or custom formulas. The platform also lets you manage quoting, pre-hedge, and post-hedge behavior with Autospreader rules. [library.tradingtechnologies](https://library.tradingtechnologies.com/trade/as-spread-configuration.html)
## Why traders use it
This setup is useful when you want to express relative value between two contracts, such as calendar spreads or inter-product spreads, while having the execution logic handle the legs. TT positions this as a professional, low-latency spread-trading workflow with colocation and proximity infrastructure for faster execution. [tradingtechnologies](https://tradingtechnologies.com/trading/tt-platform/)
## Practical workflow
A common flow is: define the spread, choose the formula, set leg multipliers, then trade the synthetic instrument from the DOM/ladder. TT also supports spread charts so you can visualize the synthetic instrument while managing the order from the platform. [tradingtechnologies](https://tradingtechnologies.com/trading/spread-trading/)
## Trading notes
Spread trading on TT is more than just clicking two legs manually; the key advantage is automated leg handling and hedge logic. That can reduce execution errors, especially in fast markets or when one leg fills before the other. [library.tradingtechnologies](https://library.tradingtechnologies.com/trade/as-spread-configuration.html)
