Date/Time: Thu, 26 Nov 2026 04:33:40 +0000
2899 VbP special effects
View Count: 323
| [2026-05-08 18:21:02] |
| MarcOh - Posts: 178 |
I had no choice but to update to the new version. Unfortunately the "VbP" study hasn't been working since then and is showing a few extra bonus numbers. Ideas? |
| [2026-05-08 18:53:50] |
Please update to the latest Pre-Release (v 2904) that has this fixed. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-08 19:58:59] |
will check it out. appriciate your quick resp and all efforts. thx
| [2026-05-09 05:47:50] |
| foxhunterskl - Posts: 5 |
I noticed that with releases after 2888 the VAP container in ACSIL showed 0 price levels per bar. 2888 was the last working version. Is this fixed with that pre-release as well?
| [2026-05-09 19:56:39] |
| Sierra_Chart Engineering - Posts: 25491 |
Getting a zero size Volume at Price container, will be resolved by recompiling the custom studies on the newer versions.
