Date/Time: Thu, 26 Nov 2026 04:33:38 +0000
ASCIL study not compiling
View Count: 427
[2026-05-08 13:38:44]
User678903 - Posts: 2
-- Starting remote build of Custom Studies Source files: Iceberg_ETH_Detector.cpp. 64-bit -- 09:37:34
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
JSON parse error: The document root must not be followed by other values.. Server text: 404 page not found
-- End of Build -- 09:37:34
Getting the above error when i am trying to compile using the: Build >> Remote Build - Standard
[2026-05-08 14:14:34]
We are aware of the issue and are working on it.
[2026-05-08 15:18:45]
epinay197 - Posts: 56
same issue here -- Starting remote build of Custom Studies Source files: xxxxxx.cpp. 64-bit --
The remote build is complete.
The build failed.
failed to generate the build environment, error while Creating Container.
-- End of Build -- 11:17:42
Found a solution with VS Code by compiling locally in the meantime
[2026-05-08 17:12:14]
Sierra_Chart Engineering - Posts: 25491
This is now resolved.
