Date/Time: Thu, 26 Nov 2026 04:33:47 +0000
Build error:including on build 3
View Count: 278
| [2026-05-08 11:35:46] |
| BenjFlame - Posts: 353 |
Hi, when trying to build my acsil file as I usually do, I get this error message. I don't think it's a local problem. -- Starting remote build of Custom Studies Source files: CustomSystems.cpp. 64-bit -- 07:35:06 Allow time for the server to compile the files and build the DLL. Server: https://build2.sierrachart.com JSON parse error: The document root must not be followed by other values.. Server text: 404 page not found -- End of Build -- 07:35:06 or on build3: -- Starting remote build of Custom Studies Source files: CustomSystems.cpp. 64-bit -- 07:36:02 Allow time for the server to compile the files and build the DLL. Server: https://build3.sierrachart.com The remote build is complete. The build failed. failed to generate the build environment, error while Creating Container. -- End of Build -- 07:36:05 Date Time Of Last Edit: 2026-05-08 11:36:26
| [2026-05-08 11:50:46] |
| Sierra_Chart Engineering - Posts: 25491 |
We are checking on this.
