Date/Time: Thu, 26 Nov 2026 04:33:43 +0000
Documentation update needed: Path for - "Always Use 'Data' Folder Within main Folder"
View Count: 323
[2026-05-08 10:57:19]
kvcornie - Posts: 56
I am only able to find "Always Use 'Data' Folder Within main Folder" under the path:
Global Setting >> General Settings >> Paths
I found a couple sections that need to update that info as they stop at "Global Setting >> General Settings. [Not a huge deal, just took me a minute to find]
Update Sections:
I found 4 instances that need to be updated in the following sections:
(A) Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
- 10. In the new installation of Sierra Chart, select Global Settings >> General Settings. Enable the Always Use 'Data' Folder within Main Folder option. This will ensure the correct folder is always used.
- Changing Data Files Folder
(B) Updating Existing Installation of Sierra Chart with Files and Settings from Another Installation
- 7. Select Global Settings >> General Settings. Make sure the Always Use 'Data' Folder within Main Folder is enabled. Press OK. If you changed this setting, then reconnect to the data feed.
(C) Simple Transfer/Copy of Sierra Chart Installation to Another Folder or Computer System
- 2. Select Global Settings >> General Settings.
Hope this is useful/desired feedback
Best,
Kurt
[2026-05-08 19:49:43]
Thank you for this.
We have updated the information for that page.
