Date/Time: Thu, 26 Nov 2026 04:33:38 +0000
What Is the Difference Between Next/Previous Chart and Next/Previous Window
View Count: 265
| [2026-05-08 07:52:43] |
| Daniel - Backtesting.club - Posts: 177 |
Hello, I’d like to ask what the difference is between the “Next/Previous Chart” and “Next/Previous Window” options. They seem to do exactly the same thing. Thank you. |
| [2026-05-08 11:51:39] |
| Sierra_Chart Engineering - Posts: 25491 |
In most cases they will be the same. A Window could either be a Chart or Spreadsheet. A Chart will always be a chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-08 11:52:47
