Date/Time: Thu, 26 Nov 2026 04:33:40 +0000
JSON parse error
View Count: 1004
[2026-05-08 21:26:08]
BenjFlame - Posts: 353
-- Starting remote build of Custom Studies Source files: CustomSystems.cpp. 64-bit -- 17:25:42
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
The remote build is complete.
The build failed.
Failed to generate the DLL file.
-- End of Build -- 17:25:44
[2026-05-08 23:41:40]
HumblyTrading - Posts: 226
I think using the visual studio debug mode would be a good backup for all of you having issues.
The error logs give you more data that way anyhow to debug.
And anytime the remote server is struggling, you won’t be slowed down
The install link is in the same drop-down as the remote build
[2026-05-09 00:19:58]
JEROME7968 - Posts: 19
My side's problem has resolved too. Thanks to the team.
Date Time Of Last Edit: 2026-05-09 01:53:09
[2026-05-09 04:57:49]
Sierra_Chart Engineering - Posts: 25491
We apologize for the continued issue. There was another new problem, with remote builds and that is now resolved. It was resolved earlier, in the evening.
[2026-05-09 18:14:34]
User116561 - Posts: 16
This is working now, thank you.
